Is there any way to remove the board from the case?
my lcd is dead and i need to remove the board.
Es esta una buena pregunta?
To begin with, you can follow this guide for the TI-84 PLUS Silver Edition of how to get the backplate off, ignore step 1 and 2 in the guide (don’t know if you can do it on your device and it’s not necessary from what I can see). TI-84 Plus Silver Edition Motherboard and Screen Replacement
A: When you have got the backplate off and it’s looking to be the same as in the guide, then you should be able to follow the guide. Keep a bit extra attention for every step so it’s looking the same as yours, the guide isn’t for the exact same model as the one you have.
B: If it doesn’t look the same, then add a picture of how it looks in your question if you don’t find how to do it yourself. Agregar imágenes a una pregunta existente
Guía
Dificultad:
Moderado
5 - 15 minutes
Guía
Dificultad:
Muy fácil
2 - 5 minutes
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 69
