Saltar al contenido principal
Un potente portátil para estación de trabajo que cabe en un paquete portátil. Tiene múltiples puertos y conectores para un entorno de trabajo portátil.
Preguntas 9 Ver todo
battery seems to be "cooking" when I put it on charge.
My battery is u/s. It sounds like it is “cooking” when I put it on charge. Bought new (genuine HP) battery - same sizzling sound - so I removed it and am using notebook without a battery. Any ideas as to what may cause this? Thank you.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Hi,
Does the battery have the correct HP part number?
The following is taken from p.45 of the maintenance and service guide for the laptop.
8-cell, 2.55-Ah (73-Wh) Li-ion battery for use in all countries and regions except Japan 493976-001
8-cell, 2.55-Ah (73-Wh) Li-ion battery for use in Japan 534057-291
Sounds as though there is either a faulty battery or a problem with the laptop’s battery charging circuit.
Given that the charger runs the laptop OK, i.e. it hasn’t damaged any components in the power supply circuits to the laptop by having higher than stipulated voltage output, it appears that it is OK.
Nevertheless it may be advisable to test it anyway. Here’s a link that shows how to test the adapter. Scroll down to find the AC adapter test procedure.
Does the laptop work OK on the battery only?
If so and if Win 10 is installed, create a Win 10 battery report to check the status of the battery and check what it says
Fue útil esta respuesta?
Puntuación 0
Sounds like your battery problem. Did you check it by changing your battery?
Puntuación 0
Añadir tu respuesta
alangreen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 53
