So I found a 2015 MacBook
So I found a 2015 i7 16gb ram 1.5 gb vram, 512gb ssd for 660 but there is a major issue, the connector for the keyboard is torn off
would it be possible to just get some solder infused in flux and put it on and solder the connector directly without replacing it. Thanks
I realize that this isn’t the right way to fix it, I’m just wondering if it would be a usable option since I can’t find a place to buy the connector
Update (06/23/2020)
So replacing the trackpad will also make the keyboard work again?
asking because the keyboard and trackpad don’t work
Es esta una buena pregunta?
2 comentarios
In this series the trackpad is more than just a trackpad! It's also the junction point for the keyboard. So it's not surprising the trackpads failure is also causing the keyboard not to work.
Have you tried using an external USB keyboard and mouse to make sure the system is even working? I would start there.
If that didn't fix things then you have to replace the MacBook Pro 13" Retina (Early 2015) Trackpad Cable which connects to the trackpad carrying both the keyboard and trackpad signals to the logic board.
- de Dan
Yes it works perfect with external keyboard and mouse
- de David bellows
