Battery draining REALLY fast
I am currently refurbishing my niece’s 2010 MacBook Pro. I’ve noticed that I’m getting 20, maybe 30 minutes tops out of a fully charged battery with very light websurfing. Here’s the equipment:
2010 Macbook Pro 2.4GHz, with 8GB of RAM
Fresh install of El Capitan on Samsung 850Pro SSD
Single webpage open in Safari, no other programs running.
Both System Profiler and coconutBattery show this battery as having a full charge capacity of 6157 mAh, and 800 charge cycles. Operating on battery shows discharge rate of 10.04 watts in coconutBattery. Voltage shown in System profiler is 12.3V. When connected to a known good charger, coconutBattery shows a charge rate of 18 Watts.
I have performed several SMC resets (appears to work, as charge light on charger port changes from amber to green for a few seconds, then turns amber again), as well as reset the NVRAM several times. I have also removed and reinstalled the battery several times.
I’m stumped as to why a 6157 mAh battery with only 800 cycles would discharge so quickly. I’ve had batteries well into 1000 charge cycles with 4000 mAh capacities last far longer than this. Any ideas?
Es esta una buena pregunta?
Is this still the original battery?
Also which model do you have the 13" or the 15"
- de Dan
Dan,
Sorry forgot to mention. This is an Anker replacement battery, purchased in 2017. And this is the 13" MacBook Pro.
- de Ruben Reynoso
Lets check the battery, install this gem of an App! CoconutBattery. Take a snapshot of the apps main window and post it here for us to see. I really we need two snapshots one with the charger plugged in at about 80% charged and the other with the charger disconnected after waiting a good five minutes. Agregar imágenes a una pregunta existente
- de Dan
@danj Already had coconutBattery installed (yes it is a great app!), I've added the two screenshots you requested to my original question. The only app running during this 5-minute period was an open browser window in Safari, set to a page with no Flash content. No changes to the webpage, just sitting there.
- de Ruben Reynoso
