Saltar al contenido principal
Lanzado el 22 de septiembre de 2017. Modelo A1864, A1897. Disponible como GSM o CDMA / 64 o 256 GB / oro, plata y gris espacio.
Preguntas 677 Ver todo
iPhone 8 Plus Won't Turn on After Replacing Screen and Battery
Hey guys, recently I just replaced my iPhone screen and battery simultaneously. I put all together and it works great. However, I woke up the next morning to the phone completely dead. I thought it’d be a simple fix but my phone won’t reset, turn on, or anything. I’ve tried everything to figure out what the problem could be I disconnected the battery and put in the charger but the screen won’t turn on either so I took out the screen and installed my old broken screen with the charger and still nothing worked. I examined the connectors and everything on the phone but everything looked fine. I could really use some help here because I’m just in high school and can’t afford a new phone.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
3 comentarios:
Did you try putting in the original battery? Did you try hooking it up to a computer and seeing if iTunes will recognize the phone?
- de
Did you try a different charger? Have you used an aftermarket charging cable before?
- de
I did try putting in the original battery and screen and arose with the same issue. I hooked it up to the computer and it refused to even recognize the phone. I tried an aftermarket cable then tried an original cable
- de
Agregar un comentario
3 Respuestas
Put back your old battery or buy a new battery and see if the phone boot up.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
I did put in the old battery however the LCD screen did not show any thing. I also put my old screen and nothing came up
- de
If Phone worked fine, then most likely battery and LCD is fine. Battery most likely had a charge in it and couldn’t charge back up due to pry damage to the Moffset(s) in the picture. If you are handy with a multimeter or have magnification… look around the circled area for missing/lifted or damaged components needed to charge your battery. Or use a Multimeter in “Diode Mode” to take the readings of the battery connector and see if they are correct or show “OL” (Open Line).
Puntuación 0
1 comentario:
I do not have those tools handy, I'm only in high school. I'm attempting to see if my AT&T has insurance on my phone to replace everything for me
- de
It sounds like a possibility that the tristar ic was damaged and it will stop charging and data transfer on the phone.
Update (06/19/2020)
Take it to a repair shop and have them test the tristar ic. It only takes a few seconds and most places will do it for free.
Puntuación 0
1 comentario:
Another thing is I did plug it in before and it charged fine. I woke up and the battery was dead, I have no idea what to do
- de
Añadir tu respuesta
Tyler p estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 27
Todo El Tiempo: 1,352
