Saltar al contenido principal
Guías de reparación y soporte para la primera generación de la Jeep Grand Cherokee (ZJ), una exclusiva camioneta SUV de tamaño mediano construida por la división Jeep de Chrysler
Preguntas 46 Ver todo
Bad transmission speed sensor no check engine light?
So I just replaced both o2 sensors & the governor pressure sensor & solenoid & my check engine light keeps on coming up for the govenor pressure sensor & solenoid! Now how is that possible? I changed them correctly, do you have to reset your jeeps ecu after replacing sensors? If so how? & I have all the symptoms of a bad transmission speed sensor but no code for that, just the governor pressure sensor & solenoid! Please help! 98 jeep grand Cherokee limited 4.0L zj automatic transmission 42re. Ohh & do I have a vehicle speed sensor & transmission speed sensor? Or are they the same thing?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Just an FYI, on the later WJs, a bad transmission speed sensor puts you into a limp home mode. (and on the 545 they recommend replacing both the input one and the output one - that’s how it tells how harsh the shift is and what gear its in)
As for your particular problem, most code readers can clear ‘current and history’ codes. If its current, it should come right back. If you really have low pressure, you will burn up the transmission if you drive it. Recommend you do a careful filter change and make sure the O-ring/seal at the filter is seated perfectly in the transmission. If you do the filter change, and sensors are good, I’m afraid the next step is serious transmission diagnostics (like pressure test).
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Deejay estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 288
