Saltar al contenido principal
Lanzado en noviembre de 2018 como una edición de la línea Pro del iPad. Modelo A1980.
Preguntas 62 Ver todo
iPad Pro 11" Not charging after screen replacement
iPad Pro 11" Not charging after screen replacement. I replaced the screen and now the device only pulls around 0.1-0.2 from ammeter. Should I be considering replacing the battery or is there a component on the logic board possibly damaged?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Update: When I disconnect the battery the ammeter shows the device pulling the proper voltage, the device boot loops, but if I screw or hold down the battery connector while it starts booting with the battery disconnected the device powers on and appears to be charging with the proper voltage but when the screen shuts off the amperage drops and the device dies.
- de
Agregar un comentario
1 Respuesta
I would have the tristar ic checked. Most repair shops should have a tool to test this. Did you disconnect the battery before you changed the screen? You might want to disconnect the battery for a minute and see if it resets.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Randy Northrup estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 304
