Charging lead pops out - "makes and breaks"
Tried several leads and have trouble with the charging - seems as though the lead / plug does not seat properly.
Charge circuit “makes and breaks” .
Any clues ?
Es esta una buena pregunta?
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Rep: 1
Any clues ?
By lead are you referring to the Lightning cable end? If it does not fully seat into the charging port then there is some type of obstruction in the actual charging port. Often times lint, dust, debris, dirt, etc from our daily use, our clothing can get stuck in the charger-port.
I would gently insert a paperclip or if you have fine tipped tweezers gently remove the items. Be careful there are vital pins in the socket that if damaged will not operate properly when you charge again.
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 58
