Saltar al contenido principal
El PowerMac G5 es un ordenador de escritorio producida por primera vez en 2003 por Apple Corporation. Esta guía revisará el proceso de reparación de un número de modelo Apple PowerMac G5 A1047 EMC 2061 de 2004.
Preguntas 196 Ver todo
Where is the memory conroller heatsink located on early 2005 power mac
I have an early 2005 Powermac G5 dual processor 2.3 with 2GB of memory. I recently started this up and have been playing around using OSX 10.4.11. I downloaded a program that shows me the temps inside. I’m sitting idle. The temps seem kind of high. Both processors are around 53 to 57 C which might need the thremal paste redone. However, the concerning temp is the memory controller heatsink that’s reading 73 C.
If this is normal for this machine or if it might just need a dusting that’s one thing. But I don’t even know where this is located on the board. Any guidance is helpful. I plan on tearing this thing down soon and giving it a through cleaning, but if there’s any places I should focus on I will.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
So I will throw an answer here in case someone comes across this with a similar issue.
I should've wrote this when it was still fresh in my mind. However, the memory controller chip is on the back side of the logic board. YAY! You have to completely disassemble the Powermac and remove the logic board. I think there was either a separate fan for the memory controller, or one of the main case fans had a vent that went to the back.
The heatsink is held on by black plastic push pins that will break very easily. I don''t remember if I had modified new pushpins from Amazon, or if I had gone the nylon bolt route. If you get the push pins off of Amazon or a similar place, you have to use a razor to trim the wings to a similar size that Apple has in there and it should work. Good luck!
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Michael estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 45
