Why is my car not firing?
I have changed the plugs and wires and still no fire to them. What all can I check to fix this problem?
Es esta una buena pregunta?
Check your crank sensor. It is the crank sensor that sends a signal to the PCM, this signal determines when the PCM fires the coil. So I would check crank sensor then PCM for spark. You can download the ignition part from the service manual right here good luck and I hope this will work for you.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,247
1 comentario
Of course the engine turns over, and there's a spark from the coil wire?
- de originalmachead
