Beats solo 3 battery won't last long
[Note: ifixit doesn’t have a category for Solo 3, so I had to chose Solo2]
I’ve had this pair for a couple years now, so when I started to notice the symptom of a charge not lasting as long as it once did, I immediately suspected the battery and replaced it. Now, with a fresh battery, I’ll charge it and still only get ~5 hours worth of use, because the battery will even drain while it is off.
I’ve also tried resetting them after I replaced the battery. Still no luck there. Anybody have a solution? Is it time to replace them?
Es esta una buena pregunta?
My daughter has a set of these awful headphones, cheap plastic and uncomfortable. I changed the battery as they went flat even when switched off, this failed to resolve the issue, so I brought another battery thinking the replacement was faulty, turns out to be the headphones are the issue and run the battery flat even when switched off. I will NEVER buy this brand again
- de Neil Newman
