Won't heat water, said to add water. Water container is full
Will not heat water, said add water, water container is full
Es esta una buena pregunta?
Audrey Steward double check the water filter in the reservoir as well as the bottom water filter. Make sure both are clean and unobstructed. Keurig K40 Bottom Water Filter Replacement After that check the water pump, check valves and tubing. Keurig K40
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 56
