Saltar al contenido principal
El Nissan Altima de cuarta generación (modelo de chasis L32A) se anunció en el Salón del Automóvil de Nueva York 2006 el 12 de abril de 2006. Fue el primer vehículo en utilizar la plataforma Nissan D más pequeña, con una nueva suspensión delantera y trasera mejorada.
Preguntas 26 Ver todo
Why cooling fan runs and engine won't start?
My car was running normally then switched off the engine for a few hours, came back and while trying to start again, cooling fan runs, no crank and engine won't start.
All dashboard lights on after single click on start button while pushing breaks (cooling fan runs), which is really weird coz engine is not hot. Another press on start button, everything goes off.
I recently changed radiator and spark plugs + 2 ignition coil.
Any idea what could be the reason and how i can fix it?
Es esta una buena pregunta?
Puntuación 0
5 comentarios
We’re is the bcm I’m having the same Problem
- de
And what all I have to tske off my part car with the same year 2007 to get this one running
- de
Help....I am having this same issue. What did you do to fix it?
- de
In my skoda fabia it was immobiliser. I just had to disconnect accu (battery) for 1 minute, then reconnect and engine started:)
- de
I have the same problem but I have a '94 BMW 3 series
- de
Agregar un comentario
5 Respuestas
Solución Elegida
It may well be that the fault with the cooling fans has drained the battery too much, when it tries to start the battery voltage collapses and the electronics give up. Try charging the battery or use a booster pack to get it started, you can then drive it somewhere to get the cooling fan problem fixed - this may well need to be a main dealer with the right diagnostics equipment.
Fue útil esta respuesta?
Puntuación 0
Respuesta Más Útil
Mine did the same and it was the engine control fuse. It's in the fuse box under the
Puntuación 1
1 comentario:
Under the what? I cant see the rest of the text
- de
This usually an indication you have a shot BCM.
Puntuación 0
1 comentario:
Where ia this located?
- de
I’m have this problem now . The guy look at it he put a used relay on my van and now the same thing is happening. I’m going to buy a new relay and get the battery charged and see what happens.
Puntuación 0
1 comentario:
Did you find out what it was?
- de
It might be immobiliser. I disconnected battery for 1 min, reconnected it and the car started
Puntuación 0
Añadir tu respuesta
Ahmad Nawar estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 26
Ultimos 7 días: 147
Ultimos 30 días: 772
Todo El Tiempo: 12,716
