Identifying and Replacing component "Q9" on Asus VG278Q
Part closeup
Board itself
I have an ASUS VG278Q 27" 144Hz gaming monitor that recently crapped on me.
I've found the part that failed but am having difficulty identifying a part number. Haven't had any luck looking up part numbers through googling.
This form factor tends to be a MOSFET, voltage regulator or diode . I'm guessing transistor based on the Q9 reference designator but then it makes me wonder what kind? NFET or PFET? Or even BJT?
The only things I can seem to make out are "21..."
Any suggestions on how to find the replacement part?
Es esta una buena pregunta?
3 comentarios
Hi! How did you disassembly this monitor? I am trying on mine but a black tape is hard attached to the bezel.
- de Leopoldo
It is really frustrating to try and disassembly it. There are some kind of tab/hooks that hold the frame together. You need to put a thin spudger to put pressure and widen the gap until the hooks undo themselves.
I'm not sure what tap you're referring to
- de thewinklesnail
Hi moybryan3. Sorry, i meant "tape", black tape.
- de Leopoldo
