How to replace the thermal fuse in Greenworks Weed Whacker #21212
Hi. I have a Greenworks Weed Whacker Model #21212. I was in the middle of using it when it suddenly stopped working. Everything checked out and working as far as extension cord and power supply. After much research it came down to the thermal fuse probably burning out. Was hoping to get some help in figuring out how to replace this AND hopefully without having to solder the replacement fuse. THANK YOU!
Es esta una buena pregunta?
Thank you for your response. Your suggestions are appreciated but must say I looked into all that before posting my question. No longer under wrnty and returning product is no longer an option. So, only recourse is to fix and repair the trimmer myself. My tech skills - as long as there’s clear instructions repairing tools myself usually ends well. Video seen here on iFixit replacing thermal fuses was thought to be helpful until I opened up case that holds the motor for my string trimmer and there was no thermal fuse to be found. So, I’m back to square 1.
- de goso
