How do I set camshaft timing
I have an 09 Kia Rio I bought a used head for. They loosened up both cams and the tensioner . Do you have a diagram so I can reset the cams
Es esta una buena pregunta?
Timing in the Camshaft. Rotate the crankshaft clockwise to 90 degrees after TDC. This will make sure all the pistons are half way down the bore. Now position the dial gauge so that it can read the lift of the inlet valve of number 1 cylinder from the top of the valve retainer. For more in for regarding auto parts you can visit motortiger.com
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 35
Todo El Tiempo: 3,084
1 comentario
I need to know what engine it has and is it a single or double cam?
- de Allan Barr
