Can I reverse the direction of flow on my oil pump - RESOLVED
Can I change the direction of flow by simply reversing the positive and negative connection to the UP2 oil pump ? The direction is backwards for my application in where it needs to be mounted.
Es esta una buena pregunta?
2 comentarios
Do you know the construction of the pumps impeller?
Many are directional so while you might be able to run it backwards you lose the effectiveness of the pump!
Maybe you need to look as the piping to it, can you reverse the connections?
- de Dan
They look like bronze helical gears and piping the system another way is unfortunately not possible. It would be sloppy and cumbersome looking.
- de Paul Cioletti
