Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 1146 Ver todo
Not restoring iPhone 7 plus
Hello I have an iPhone 7 Plus that recently got a little wet and then it went to boot loop and when I try to restore it turns off during “waiting for iPhone” and won’t turn back on if anyone knows how to get past that that would be great thank you
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
If it got wet you need to take the phone completely apart and pull all of the covers on the motherboard and clean the corrosion with a qtip and alcohol. You also need to clean all of the connectors. Use a soft brush. There is a possibility that the screen is damaged and may need to be replaced. That may still not repair it. Water damage can a lot of problems. Of starts working it could work for years or a few days. You may micrsoldering repair done to repair the phone. If you need that I would recommend jessa at ipad rehab ipadrehab.com or Jason at sts telecom ststelecom.com I hope this helps
Fue útil esta respuesta?
Puntuación 0
Comentarios:
Hello I know the water damage repair but I don’t know why it turns off
- de
It's water damaged anything can happen. You never know what is corroded or shorted and can come out of nowhere. If it's been wet it may have hidden corrosion and it can get worse causing issues.
- de
Alright just cleaned it
- de
Do you have a sonic cleaner and use ec cleaner. It really helps getting hidden corrosion off.
- de
No I don’t but where do you get one?
- de
Mostrar 1 comentario más
Añadir tu respuesta
Noah estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 40
