Saltar al contenido principal
2.26 o 2.4 GHz / Carcasa Unibody de plástico blanco
Preguntas 646 Ver todo
Pregunta Cerrada
How to test power button / keyboard?
Is there a way to power this on without keyboard, similar to what is possibly on older macbooks by shorting two connectors on the Logic board?
Mine suffered a liquid spill and now will not turn on. I cleaned corrosion, etc from logic board, but still will not turn on.
Logic board could be bad, but want to rule out keyboard/power switch first.
Update:
Tried dishwashering the upper case, but no difference
Es esta una buena pregunta?
Puntuación 0
3 comentarios
Thanks RJ. Somehow when I searched I think I must have thought that one was talking about the 1181 instead of the 1342, when it was the other way around...
Anyway, thanks for the link.
- de
Still no luck with this 1342, but I did notice that the power cord flashed the green LED briefly when I first connected it, then flashed orange several times, then remained dark... not sure what that could indicate, so about to do some research.
- de
HMMM, cleaned the magsafe port on the 1342, then connected power to it, green light lit steady for about 2 minutes, then slowly faded to black, probably about 25 seconds to fade... disconnect and reconnect and it stayed black.
Weirder and weirder. (at least to me)
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Here is a link to a previous question that answers your question with pictures. Choose the one that fits your computer. Good luck.
Where on the logic board are the power-on pads?
Fue útil esta respuesta?
Puntuación 3
http://www.youtube.com/watch?v=raJxRiaQ2...
connect pin 5 to pin 6 on the keyboard ribbon cable jack. You can remove the ribbon cable first to eliminate the keyboard.
Puntuación 1
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 7,921
