Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Nintendo handheld device released February 2011, identified by model number CTR-001.
Preguntas 387 Ver todo
How to get stuck screws on the inside loose?
I am trying to fix the L and R buttons on my 3ds so I can use it as a good gaming system again.
One problem I am having is that the screws on the bottom inside cover. Here is a example picture of the screws I mean.
How would I get the 2 that are stuck lose without breaking the screws or my 3ds cover?
Any tips or ideas will be much appreciated.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Are the screws stripped or are they screwed in hard?
- de
@eke0909 I am not sure if they are stripped or just stuck, they probably are striped but I have the other 3ds that I am getting the parts I need from, the screws on that one just seem to be stuck, so tips for both would be very helpful.
- de
@veronique2020 thanks for that page, but it does not help me in this situation since these screws are in a little hole making them really hard to use any of the tricks in that article.
- de
If you have a sharp tip of soldering iron - carefully heat the screw by touching it. (i do not know how deep are these screws). Either way, you need to take a chance!
- de
Mostrar 2 comentarios más
Agregar un comentario
SALTEA LA ACTUALIZACIÓN
Ahorra reparando con un kit todo en uno.
Compra Kits de Reparación
1 Respuesta
You may need two people. One to push down on the proper size screw drive and the other person to put vise crips around the shaft of the screw driver to turn the screw driver. Careful not to strip the screw head.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
aRealCyborg estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 41
