There was something rattling in my controller and this came out.
Where is this piece supposed to go? It fell out when I opened it
Es esta una buena pregunta?
You may check out all these teardown and replacement tutorials, as I can see that the metal component can only be attached to the controller board, you may try your luck and find it there.
https://www.youtube.com/watch?v=5P0Seo7e...
Desmontaje del Mando (Controlador) Inalámbrico de la Xbox One
Sustitución de los Botones Frontales del Mando (Controlador) Inalámbrico de la Xbox One Model 1708
Guía
Dificultad:
Moderado
10 - 25 minutes
Guía
Dificultad:
Difícil
30 minutes
Fue útil esta respuesta?
The piece that fell out was plastic, it probably looked metal due to the lighting. I will check out the teardown videos and see if they can solve my issue.
@logibeak Did you reassembly it again? Will it work?
Is this the part that go on the side of the analog stick module where the joystick button is ?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 749
