Saltar al contenido principal
Guías de reparación y soporte para la memoria de acceso aleatorio utilizada en las computadoras.
Preguntas 20 Ver todo
New RAM with same specs besides size won't work
I just tried replacing my old 2GB RAM sticks with 2 new 8GB RAM sticks, besides the size, they have the exact same specifications. They both run at 1.35/1.5V, 1600MHZ, DDR3. The old is DDR3L, but the new is also specified to run at lower voltage. I have looked at the specs for my motherboard and it has 2 RAM slots both expandable up to 8GB. I know the slot type is the same, as they do fit in, and I have tried applying extra pressure to insert them as far as they will go, but when I start up my machine the monitors come up black and it makes a continuous beeping sound. I can hear the fans run and the lights all come on. Thank you for taking the time to read my question, and especially for any responses.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Dear Myopic, what the h-ll are you doing this to? Please be precise.
- de
@samuelrogers ... lol im with @mayer .....lost. Please indicate your model machine so we can view oem specs and please list the sku# or link of what you purchased so we can compare. It sounds like its not posting due to not liking the ram. post so we can view and help
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
If your motherboard supported 8 GB expendables then follow the steps below:
  • Remove both the RAM and clean the slot carefully. The RAM slot must clean and remove carbons from points.
  • Now clean your RAM pins and insert single RAM in a slot and turn on your PC. If your PC is working means your board is not able to handle high capacity of RAM.
  • Now, do the same thing with another slot to confirm there is no fault in the slot.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Samuel Rogers estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 93
