Water pump system Ford Escape 2012 25 lt it's coolant close to the wat
It's leaking coolant near the water pump should I change water pump thermostat
Es esta una buena pregunta?
More likely to be the water pump itself or perhaps a bypass or other hose nearby to the pump that is leaking. You need to visually confirm what is leaking with an inspection mirror and directing a strong light into the hard to see areas around that pump to see exactly where the water is coming from. There are also a lot of low prices boroscopes that hook up to smart phones these days that can help with tight inspection jobs like this.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 105
