Saltar al contenido principal
A2115/2019/ Procesador desde 3.0 GHz de 6 núcleos core i5, hasta 3.6 GHz de 8 núcleos i9. Lanzado el 19 de marzo 2019.
Preguntas 100 Ver todo
Help with my keyboard woes, please?
This computer (and the keyboard that came with it) is only 4/5 months old.
I noticed my V key was sticking. Since I’ve used Mac for a while and had to clean and reattach keys before, I figured I could do it again. I took the key off and cleaned it but when I attempt to replace it, it stays stuck down. It will not bounce back up. Like an imbecile, I took off the neighboring key to see if I could figure it out.
Long story short….I now have two keys off that I can’t put back on correctly. Does anyone know what I did wrong and how to correctly reattach? Videos I watched on YouTube do not have the clips oriented the same as the keyboard I have now.
Keyboard model A1644
Bluetooth
Compact
Thank you in advance.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Comentarios:
Which keyboard do you have? I assume it's a real Apple unit
● Is it USB wired or a Bluetooth?
● Is it a compact model or the Extended model with the number pad?
If you're not sure take a picture and post it here, there should be a model sticker on the bottom Agregar imágenes a una pregunta existente
- de
@danj Done. Thank you.
- de
Agregar un comentario
1 Respuesta
Review this guide iBook, PowerBook & MacBook Keycap removal & fitting
If you think you have a broken part here’s a good source for the needed part Magic Keyboard keys
Fue útil esta respuesta?
Puntuación 0
Comentarios:
Thank you for the help, but that is not the same type of clip used on my keyboard. It is a different shape. I will see if I can get a good photo of it.
- de
@tink78 - Take a look at this Apple Keyboard Key Repair Guide Magic Keyboard A1644 MLA22LL If you look on the back side of your keyboard it will have a label which would be useful to know.
- de
@danj I added pictures of the back for you.
As for the link, I followed that tutorial but it didn't work. The key still stays stuck down.
- de
@tink78 - Your second image of the back side with the model number was what was needed A1644
- de
@danj That information was in the post. Thanks!
- de
Mostrar 1 comentario más
Añadir tu respuesta
Sara estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 149
