Can paper slip through gaps in trackpad?
Could a small thin piece of paper (say, 1mm x 2mm) fit through the crack or gap on the side of the Macbook Air 11" trackpad? And if so, is it likely to cause any damage or harm in the short or long term (e.g. through causing something to overheat)?
Es esta una buena pregunta?
2 comentarios
Re Paper thickness- it's inkjet printer photo paper with a matte finish. That is, it's slightly thicker than normal paper. The size of the paper would literally be equivalent to two or three short hair strands (like an eyelash) but like I mentioned, I'm just wondering if this is something worth taking to the Genius Bar to ask them to open it up and clean it, or if I should just leave it be.
- de JaCe88
It's a gamble at this point. Like ABCellars and I said it likely wont cause over heating or shorting but my fear still remains in it possibly jamming the fan (although the odds of that are very slim). It's up to you on this one. Might be a good idea if you have bad luck :)
- de Phillip Takahashi
