iPhone 7 randomly restart / reboot every 20 minutes
NOT SOFTWARE PROBLEM
Which part needs replacement?
Es esta una buena pregunta?
You need to get a new battery. You’re battery inside the iPhone cannot hold enough charge to keep your phone on for extended periods of time so I would get a new battery and it should fix your problem
Fue útil esta respuesta?
All parts except motherboard are less than 1 month old. It is problem on motherboard and i am wondering which ic is in need of replacement.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 55
Given the age of the phone i would test it out as it could need a new battery. Test with a new battery or does it continue to do it even when on charge?
- de Jade Richards
@Jade Richards the phone has all parts new except motherboard. I meant, which ic on motherboard is in need of replacement - i newer got phone like this one.
- de Filip Georgievski
Battery is aaa+
I forgot to mention. But i used same batteries on 100+ phones and none had that problem. Battery health is currently 99%.
