Saltar al contenido principal
Modelo A1418 / Finales de 2012 / 2.7 y 2.9 GHz Procesador Core i5 o 3.1 GHz Core i7
Preguntas 212 Ver todo
What is the highest speed, proccesor that can be installed?
So I have a late 2012 iMac that I got for free from my school, I want to put a 1 TB SSD in it as well as 32gb if that’s possible, and I want to know what processor I can put in it to give it the best specs possible.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Here's a listing of your models series: iMac13,1
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The best CPU you can install in this series is a 3.1 GHz Core i7 (I7-3770S)
As far as RAM its limited to 16 GB.
Depending on what drive option the system came with you may not be able to add a second drive. The SATA HDD models don’t have the ability to add in the PCIe/NVMe blade SSD drive, If you got a Fusion Drive system you already have two drives present (you’ll need to break the set before you can remove either) and the blade only model can have a SATA drive added with adding the needed HD SATA cable.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
David bellows estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 26
