Battery for EARLY 2016 MacBook Pro 15 inch?
I have an early 2016 MBP 15inch with a swollen battery. All I find for kits is for late 2016. Are these the same? If not, any thoughts on how I can replace my battery?
Es esta una buena pregunta?
Here’s the 2015 model battery replacement guide Reemplazo de la batería de MacBook Pro 15" con Pantalla de Retina de Mediados de 2015
And here’s the 2016 model battery replacement guide Reemplazo de la batería en la Macbook Pro 15" Touch Bar de finales de 2016
You’ll find the needed battery replacement kit for your system which ever one you have.
Guía
Dificultad:
Difícil
45 minutes - 2 hours
Guía
Dificultad:
Difícil
1 - 3 hours
Fue útil esta respuesta?
Great. Thanks! Do you know if the torx driver problem that someone commented on with the kit was solved? I'd hate to get 60 steps into the process to discover the tool doesn't work.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 137
5 comentarios
Apple didn't make an Early 2016 model, all they did is offer an updated Mid 2015 model until the touch bar models came out.
Double check by accessing your systems S/N under: About This Mac and looking it up here EveryMac - Lookup
- de Dan
Thanks. I wonder why everyone calls it late 2016 then, and not just 2016? By the way, your link doesn't work.
- de Stephen Deban
It works, It gets you to a web page to plug in your systems S/N to find your system. I just checked.
- de Dan
It does. Didn't a minute ago. Thanks.
- de Stephen Deban
@sdeban - I suspect, session time outs due to overloaded Internet.
- de Dan
