Braun EP100 Exact Power Beard Trimmer, trims and shapes beards and mustaches; outlines precise beard and mustache contours.
Preguntas 3 Ver todo
hair trimmer cut hair very short period, WANT TO CHANGE BATTERY
Type and capacity of battery to braun ep100
What volt
What watt
What mah
update
Great thanks for all who help me
update
Please if possible
Answer on one more question
Very important!!!
What capacity of battery must be in broun ep 100, there is 1 battery, but
What capacity?
500 mah or 1000 mha
Very important
Great thanks
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
One of the clearest and most direct questions I've seen asked on Answers in my time here.
por
The higher the maH the longer it will last on a single charge.
por
the person who wrote the how to guide also said he used a higher mAh battery and his charger didn't last so long. something worth considering
por
Agregar un comentario
3 Respuestas
Solución Elegida
http://forum.eserviceinfo.com/viewtopic.... I found this link to how to get to the battery (page 2)but couldn't find what exact battery was in your trimmer. You will be able to find that by taking the trimmer apart and then matching it up after. good luck
Fue útil esta respuesta?
Calificación 7
Comentarios:
+ for finding out how to change it
por
Yes indeed--I looked for some time with no luck. +
por
That wasn't easy to find but you need - (3 AA-size, 1.5V)
http://www.braun.com/global/male-groomin...
I'd also get a battery charger and rechargeable batteries like this one: http://www.google.com/products/catalog?c...
Calificación 5
Comentarios:
Good research on your part also. +
por
Only the EP 15 and Allstyle use the 3 AA size batteries. the Battery on the EP 100 is soldered to the logic board
por
Very good OT, I missed that.
por
Well here is a replacement R17 AA NiMh Battery With Pin Tabs 1650 Mah 1.2V Battery Measures .559" x 1.97", 14.2mm x 50mm Fits Braun Models: Action Line, EP50, EP60, EP80, EP100, 540, 570 from here http://www.electricshaverstore.com/get_i... and here is the service documentation. The EP100 actually is a Braun 5601
Calificación 3
Comentarios:
+ nice searching
por
+ You have a plethora of resources.
por
;-) Could not fix some of my old "stuff" without those resources. I actually purchase and repair according to the manuals I can get, makes my hobby easier.
por
Añadir tu respuesta
IGOR estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 30
Todo El Tiempo: 5,383
