Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
La actualización de marzo de 2015 del MacBook Air de 13" de Apple presenta procesadores Intel Core i5 e i7 de quinta generación, lo que resulta en un rendimiento ligeramente mayor y una mayor duración de la batería.
Preguntas 424 Ver todo
A1466 MacBook Air 2015 does not power on
Have a Macbook Air here that will not power on anymore. The light on the magsafe connecter comes on when it is plugged in and turns orange but nothing happens when the power switch is pressed.
From what i’m told it first just started to not power on then a few weeks later it would suddenly power on when tried then the owner was afraid to switch it off and left it powered on and it went to sleep after which it never powered on again.
I’ve opened it and disconnected the battery and it still does not power on when the magsafe is plugged in .
I’ve a good few years experience repairing PCBs but the only equipment i have at home is a multimeter. Can anyone point me in the direction of test points or a guide to troubleshooting this? I’m fairly competent with electronics repairs so please go into detail if possible.
Thanks in advance anyone! Any help will be greatly appreciated!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits para Nintendo Switch
Una solución rápida para volver al juego
Comprar kits de Switch
1 Respuesta
Any sign of liquid damage in this MBA ? Did you remove the logic board and made a visual inspection of the two sides (magnification would help). It takes only a little corrosion on a critical component to kill the board.
Fue útil esta respuesta?
Puntuación 0
Comentarios:
I haven't completely removed the logic board yet as i'd like to know a bit more before i go that far but i'm fairly certain there have been no spillages
- de
I saw many MBA boards that were very clean, no sign of liquid damages but one component corroded, Hard to know where it comes from but once repaired the MBA was ok.
- de
Añadir tu respuesta
Cricky Lyttle estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 20
