Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2.2 GHz (Turbo Boost hasta 3.4 GHz), 2.5 GHz (Turbo Boost hasta 3.7 GHz) o 2.8 GHz (Turbo Boost hasta 4.0 GHz) con 6 MB de caché L3 compartida.
(MacBook Pro 15" Retina Screen, Mid 2015) Display Issues
Screen flickers and has vertical lines on right side of display. Problem started out small and intermittent for two days and suddenly got worse today. Display issue does not show up on external monitor. I have already tried software fixes like resetting PRAM so problem is most likely hardware. Out of warranty and don’t want to get overcharged at local apple certified repair shop, hoping to get a clue to what the problem is before taking it in. Any help appreciated!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Sadly your internal display is bad. You’ll need to replace it to fix this. Here’s the gunned you’ll need to follow: Reemplazo de Pantalla para MacBook Pro 15" Pantalla Retina Mediados 2015
Now the shoe drops! These displays go for big bucks! This is because many had bad anti-defective coatings. A new one goes for over $600 !! A used one can be half of that if you can find one 15” Retina MacBook Pro Display Assembly, Apple P/N: 661-02532
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Jessica Herndon estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 29
Todo El Tiempo: 3,279
