Hi @ry1808 ,
Please verify the model number of the dishwasher as the number you posted shows no results.
Also, if possible check what is states in the installation manual that came with the dishwasher, regarding the dishwasher’s water supply temperature, as a lot of dishwashers require that the water supply temperature is 120 deg. F (49 deg. C) at the dishwasher.
It may be that the dishwasher’s heater element is not the problem but the water supply temperature is.
The heater may be only used to boost the water temperature if a Hi-Temp wash option (or similar) is selected and also for drying but the water temperature is starting from a higher base temperature.
Hi @ry1808 ,
As I suggested, according to the the following extract from the installation guide for the dishwasher (see p.8), it does require a water supply at 120 deg. F.
“ WATER SUPPLY REQUIREMENTS
■ This dishwasher has a water heating feature and also requires a connection to a hot water supply line.
■ A hot water line with 20 to 120 psi (138 to 862 kPa) water pressure can be verified by a licensed plumber.
■ 120°F (49°C) water at dishwasher “
Have you checked this out, you didn’t say?
Also have you checked that the heater element - part #30 is OK or not by disconnecting the power from the dishwasher and testing the heater element with an Ohmmeter before going to all the trouble of removing/replacing it in case it is not the problem, you didn’t say?
1 comentario
Ah yes, I got the wrong number. The correct model number is:
WDT780SAEM2
- de Richard Youden
