Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Support for the third generation of Chrysler Town & Country spanning model years 1996-2000.
Water leak in straight stream out of the timing cover
My van has a straight stream of coolant squirting out between the timng cover and motor how do I fix this thanks in advance
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Hi,
What is the model year and engine size?
- de
Model is a 2000 it has a 3.8 engine thanks
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Replace the timing cover gasket.
UPDATE 3/5/20
Here’s how to do it:
https://www.autozone.com/repairguides/Ch...
Fue útil esta respuesta?
Puntuación 2
1 comentario:
I kinda knew that but how to do it I don't
- de
Hi,
Check that the water pump is not leaking coolant.
Here’s a link to the service repair manual for your series vehicle.
Scroll down and click on the Cooling System link , pass the reCAPTCHA test and when the pdf file opens go to p.7-19 to find the procedure to inspect / replace the water pump for a 3.8L engine.
Puntuación 1
Añadir tu respuesta
Daniel Billings estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 52
Todo El Tiempo: 403
