Saltar al contenido principal
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
Preguntas 199 Ver todo
Is it posslible to change the LED?
Hi there,
i´d like to have an other colour in the back and menue keys. Is it possible to change the (i bet its only a single one) led behind them? You don´t open the galaxy s2 this far.
Thank you for your Answers.
Greets Kevin
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
if you can open your phone to the led then you should be able to desolder and resolder any colour you like...finding one the same size is the only problem.
Fue útil esta respuesta?
Puntuación 3
3 comentarios:
+ Hi Polly, good answer. LEDs sizes are given as diameter measurements in mm (millimeters) and voltage. Measure the voltage going to the existing LED and it's diameter. Purchase accordingly.
- de
I found some of these ages ago..as you do.. thought they looked like fun, have seen many bigger ones being used with tiny battery and magnets on www.makezine.com just never had anything i needed a small LED for..
- de
Añadir tu respuesta
Kevin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,959
