Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Lanzado el 25 de septiembre de 2015. Modelo A1687 / A1634. La Reparación de este dispositivo es similar a las generaciones anteriores, requiriendo destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16, 64 o 128 GB / Silver, Gold, Space Grey o Rose Gold.
Preguntas 965 Ver todo
iPhone 6s Plus earpiece is not working
Hey there. I swapped out the battery but the earpiece doesn't work anymore. The front camera works fine tho . I did forgot to disconnect the battery when removing the screen. Everything works but that.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
If you are sure the connector is seated properly the next step would be replacing the front camera flex cable as this is also responsible for the speaker and mic.
 It doesn’t sound like you damaged anything electrical disconnecting the flexes with the battery connected. But this would be a different story if you tried connecting them back with the battery connected.
Fue útil esta respuesta?
Puntuación 2
Comentarios:
It was not seated In I believe, but anyways thank you!
- de
Añadir tu respuesta
Jose Vazquez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 81
