Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2687 Ver todo
What is this small golden connector, and why won’t it go back in?
Just underneath the battery connector, what is the golden connector, with a black pad on top, that just won’t go back in, circular in shape. No matter how hard I press it won’t go back in. What is it for, and could it be related to my phone not charging?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios:
Do you have an image of the golden connector?
If it’s the one I’m thinking about then yes it is related to the iPhone not charging as it is part of the charging port. If it is by itself just hanging loose or completely broken off of the charging port then it will need to be replaced.
- de
I think you might be talking about the antenna leads. Is it connected to a long, thin wire?
- de
Agregar un comentario
2 Respuestas
pretty sure you’re talking about the wifi antenna lead, if you dont plug it in your wifi wont work
(one i found on google - https://www.replacebase.co.uk/apple-ipho... )
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Yeah, I don’t know why, I put it it over the connector, screwed down the metal plate and everything seems to work fine
- de
If you try to force the connector on you could have inadvertently damaged the socket on the main board by bending it out of shape, in which case you will struggle to get the connector to locate.
Puntuación 0
Añadir tu respuesta
Charlie While estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 69
