Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El reloj inteligente de Apple de cuarta generación con conectividad celular opcional lanzado el 21 de septiembre de 2018.
Torn ribbon ground replacing screen. See picture..
Is there a way to repair the ribbon after it has been torn? It is the two outer ribbons that seem to be grounded to the chassis.
Can this be repaired or do I need a new ribbon assembly?
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
4 Respuestas
Solución Elegida
I actually put it back together as is and it’s working fine. I have no idea what they are for but they’re not affecting functionality as yet.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Is your watch still working ok. I just tore the same cables?
Thanks
- de
Yes it can be repaired with the right tools and experience. Short answer, no don’t waste your time. Time is money and that part is 50x cheaper to just replace instead of spending hours to fix.
Puntuación 0
2 comentarios:
- de
I have been searching for a source for a replacement "ribbon ground", but can't find any :-o
Does any of you know of a good source and a link to it?
Thanks!
- de
Will it make a ometv chatroulette  chat avenue   difference if I use the original cable? Thanks
Puntuación -1
++https://ometv.vip/++
++https://bazoocam.live/++
++https://omegle.monster/++
++https://chatzy.xyz/++
++https://ometv.icu/++
Puntuación -1
Añadir tu respuesta
canicoll estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 1,295
