Fridge failing after approx 6 hour runtime
Hi - older Maytag model MF 2557 HEB not working consistently. Repair person was in and checked compressor and declared relay start to be issue. The start and capacitor were replaced and all coils cleaned. The fridge and freezer ( including ice maker) worked fine for about 6 hours, then stopped. After it failed you can hear the cycling ( whine click of the start relay?), fans are running but no cooling. We have now also replaced the thermistor and evaporator thermostat in hopes that one of these parts had failed - still no luck. Every time unit is disconnected from power and reconnected it works for another 6-8 hour period then stops.
Is there a next step or will it need to be replaced ;-(. Thx
Es esta una buena pregunta?
