Why is it getting so loud?
While it's spinning the cloths there is a loud almost rubbing sound
Es esta una buena pregunta?
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. ... If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 29
