Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 1498 Ver todo
Home button unresponsive after screen replacement?
Was opening up the phone for a screen replacement. Have done many before with no issues.
I was trying to seperate the screen from the frame with my metal pry tool and accidentally cut into the actual screen itself by the home button area. I pulled it out straight away and it didn’t go in very deep.
After this, I did the screen replacement as normal but once I turned it on it said “Touch ID could not be activated on this iPhone” and the home button doesn’t even click; it is like how it is when the phone is turned off.
Any ideas? Would be hugely appreciated as you’d be saving me from buying a new phone for my friend becuase I wouldn’t be able to put up with the guilt.
Thanks.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits para Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
2 Respuestas
Solución Elegida
If the home button ribbon is comprised its usually fixable but needs a solder repair. If not you can buy a Bluetooth replacement button online if the original button is knackered
Fue útil esta respuesta?
Puntuación 2
it may be repairable with micro soldering but will probably need replacing, unless you pay apple upwards of £300 to install and sync a new one then an aftermarket one is the only option but Touch ID will never work with an aftermarket one.
Puntuación 1
Añadir tu respuesta
Rafay Siddiqui estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 19
