Saltar al contenido principal
Procesador Core 2 Duo de 2.2, 2.4, 2.5 o 2.6 GHz
Preguntas 759 Ver todo
Why will hard Drive to SSD not allow for startup?
I recently took my entire Macbook pro early 2008 completely apart to see how everything ran and decided that I wanted to upgrade a couple of things. So far, I upgraded the ram which does work, however I upgraded the original hard drive on the computer to a 2.5'“ Sata 6 Gb/s SSD which hasn’t gone over very well. I transferred over all my files cloning the original drive and putting it onto the SSD, but during startup I get the prohibitory sign. I’m assuming that means there’s a boot issue. How do I solve this?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Your SSD is not able to run in your system! Your computer has a SATA I (1.5 Gb/s) interface, The SSD you put in is a SATA III (6.0 Gb/s) drive most today are fixed speed meaning they can’t run in the older SATA I or II systems. You’ll need to return the SSD and get one that its spec sheet states clearly it will work in a SATA I system. As an example the Samsung 860 EVO SSD states it very clearly.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Sean Stumpf estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 39
