Saltar al contenido principal
Versión renovada del iPhone 3G con velocidades de procesamiento más rápidas. La reparación de este dispositivo es similar a la 3G y requiere destornilladores simples y herramientas de palanca. Modelo A1303 / 16 o 32 GB de capacidad / respaldo de plástico negro o blanco.
Preguntas 1500 Ver todo
Charging problem after LCD and Dygitizer change, no auto-dim,bat drain
So I cracked my screen and replaced it, right after I noticed that the unit is getting odly warm and battery drains verrrrry fast,(10% in 5 min) that is not normal... also when I make a phone call and talk the screen is always on and the auto dim light doesn't work. I disabled 3G, Data, Vibrate, Dimmed light to 10%, disabled notifications and location, airplane mode... SAME ISSUES :S.... Please give me some hints....
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
If the screen lock isn't working when youre in a call, then the proximity sensor is bad. You damaged the ribbon during replacement of the screen or you received a bad one. This could easily cause the battery drain. Try disconnecting the ribbon and see if it show similar symptoms (other than the proximity sensor not working). If so, replace the ribbon
iPhone 3GS Proximity Sensor Ribbon Replacement
Fue útil esta respuesta?
Puntuación 4
Añadir tu respuesta
NIck estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 787
