Saltar al contenido principal
Segunda generación de iPhone. Modelo A1241 / 8 o 16 GB de capacidad / plástico negro o blanco de nuevo. La reparación es más sencilla que el primer iPhone. Requiere destornilladores, curvas y herramientas de succión.
Preguntas 1148 Ver todo
horizontal 'lines' on screen, after a slight 'knock' to back
Hi, I recently managed to knock my phone against a low post in the street. I knocked the back of the phone whilst it was in my pocket.
I've now noticed that there 'lines' at the bottom of the screen - I assume this is possibly due to a dodgy connection to the LCD matrix?
1. Do you think it's fixable [no other visible 'damage' to the screen?
2. or is it possible damage to the logic board?
The 'lines' are on every screen and have the same colour - dark blue? They are even getting longer, though I don't use the phone now?
Thanks in advance for any help - compassion ;^)
Es esta una buena pregunta?
Puntuación 8
10 comentarios
The bottom of my screen has grey horizontal lines which stay still. However I have dark blue lines on the top of them, which is duplicating the image behind it, and also moving
- de
Black horizontal lines are spread all across my phone screen why?
- de
Thin black horizontal lines which on my screen is it permanent or we can solvents it
- de
Mine has light blue vertical lines that click stuff when they want to and it gets annoying
- de
I too get a black line at the bottom of my tablet what should l do ???? Will it remain like that?
- de
Mostrar 5 comentarios más
Agregar un comentario
7 Respuestas
Solución Elegida
This could be caused by two things.
One - LCD connection has come loose.
This is the simple and free cause as all you have to do is take the digitiser (screen) off and re-seat the LCD connection. If this fixes the issue i would highly recommend buying some Anti-Static Kapton tape. This tape is high quality electrical tape with strong adhesive and heat tolerance.
Polyimide Tape
Two - The LCD has been damaged
This is the harder and more expensive cause as the LCD has been damaged. As per the name LCD (Liquid Crystal Display) if it is knocked or bumped hard enough it causes the "liquid" to displace itself possibly causing those horizontal lines you now see. However all you will need to do is replace the LCD and you will be good to go.
Here is a link to the part you will need to buy
Here is a link to the guide you will need to replace it if you do not know how.
Hope this helps :D
Imagen de iPhone 3G Display
Producto
iPhone 3G Display
$29.99
Imagen de Polyimide Tape
Producto
Polyimide Tape
$9.99
Fue útil esta respuesta?
Puntuación 5
5 comentarios:
I have a iPhone5s and it has black lines at the bottom and my screen won't work. What could be wrong? Could it be bcz I dropped it or banged it on something
- de
hi,
my Iphone 8 fell yesterday and the protector screen broke, however it has no damage on the actual screen.
but there is two vertical lines underneath the screen now and the touch screen is not working over those two lines.
do i need to replace the whole screen or how do i fix it?
- de
I have iphone 7plus got a single yellow vertical line touch is working
- de
mine has horizontal lines on the screen. how much does it cost to fix it if i take it in to a repair shop?
- de
Hi I just put my phone on my desk and the next morning I find it with black lines and I can’t do anything I’m scared pls help my mom will kill me and do I lose my tik tok account to
- de
I had the same issue on an iPhone 4S and I fixed it by warming it up to body temperature for 30 minutes or so. The lines gradually disappeared!
Puntuación 5
11 comentarios:
my phone has also horizontal lines at the bottom... is it really working by warming? many thanks!
- de
surprisingly useful!! thank you!!!
- de
how did you warm the phone
- de
I held it between my legs :)
- de
So, you didn't have to replace the screen? My iPhone 5s has the same issue and I don't know what to do. I would appreciate any advice
- de
Mostrar 6 comentarios más
help me there is a small blakcl ine on the right screen on my iphone 6 :(
Puntuación 2
1 comentario:
Same to me though...
- de
Hmm.. It depends on the lines. If they're black, it's usually the lcd. If white, then it's an issue with the digitizer. Yes, it can be repaired. If their white, you can try reconnecting the display cables, and cycling the battery. If black, you can easily replace the lcd, on that phone
Puntuación 0
4 comentarios:
It was a very helpful tip n I found the problem is with digitizer. Now the phone is working fine. Thanks
- de
My lines are purple And i found them only in my camera please tell me what should i do?
- de
What about purple all over, it comes back and leaves
- de
mine was a series of green red black lines going downward then just quit
- de
i need help. Currently my phone is black(bottom part of it) and the top part is mixed with purple dots and i cant fix it.I tried a the power method and such but i still couldnt make it work. Please help. (Samsung note 4)
Puntuación 0
3 comentarios:
You need a new display assembly,-/. Your lcd is damaged
Galaxy Note 4 Screen
Samsung Galaxy Note 4 Display Assembly Replacement
- de
My iphone5s some unresponsive touch .it cause a black thin horizontal lines on bottom.it increase while using brightness.what is the problem how to fix ?any body give idea please
- de
My iphone 8plus has verticle lines and screen seems a bit deem then it used to be. Text also reflecting back on screen like copying of it. Not damaged or fall on ground for sure. Please advise. Does apple cover if its under warranty to fix it?
- de
I have a Samsung 8+, just recently, I noticed a black horizontal line on front camera ( unable to do selfies ) what can I do ?
Puntuación 0
i have iphone6 which displays on and off showing several horizntal lines….what exactly issue is?
Puntuación 0
Añadir tu respuesta
binaryop8 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 56
Ultimos 7 días: 331
Ultimos 30 días: 1,231
Todo El Tiempo: 387,644
