Segunda generación de iPhone. Modelo A1241 / 8 o 16 GB de capacidad / plástico negro o blanco de nuevo. La reparación es más sencilla que el primer iPhone. Requiere destornilladores, curvas y herramientas de succión.
Preguntas 1498 Ver todo
horizontal 'lines' on screen, after a slight 'knock' to back
Hi, I recently managed to knock my phone against a low post in the street. I knocked the back of the phone whilst it was in my pocket.
I've now noticed that there 'lines' at the bottom of the screen - I assume this is possibly due to a dodgy connection to the LCD matrix?
1. Do you think it's fixable [no other visible 'damage' to the screen?
2. or is it possible damage to the logic board?
The 'lines' are on every screen and have the same colour - dark blue? They are even getting longer, though I don't use the phone now?
Thanks in advance for any help - compassion ;^)
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Comentarios:
The bottom of my screen has grey horizontal lines which stay still. However I have dark blue lines on the top of them, which is duplicating the image behind it, and also moving
por
Black horizontal lines are spread all across my phone screen why?
por
Thin black horizontal lines which on my screen is it permanent or we can solvents it
por
Mine has light blue vertical lines that click stuff when they want to and it gets annoying
por
I too get a black line at the bottom of my tablet what should l do ???? Will it remain like that?
por
Mostrar 2 comentarios más
Agregar un comentario
4 Respuestas
Solución Elegida
This could be caused by two things.
One - LCD connection has come loose.
This is the simple and free cause as all you have to do is take the digitiser (screen) off and re-seat the LCD connection. If this fixes the issue i would highly recommend buying some Anti-Static Kapton tape. This tape is high quality electrical tape with strong adhesive and heat tolerance.
Polyimide Tape
Two - The LCD has been damaged
This is the harder and more expensive cause as the LCD has been damaged. As per the name LCD (Liquid Crystal Display) if it is knocked or bumped hard enough it causes the "liquid" to displace itself possibly causing those horizontal lines you now see. However all you will need to do is replace the LCD and you will be good to go.
Here is a link to the part you will need to buy
Here is a link to the guide you will need to replace it if you do not know how.
Hope this helps :D
Imagen iPhone 3G Display
Producto
iPhone 3G Display
$29.99
Imagen Polyimide Tape
Producto
Polyimide Tape
$9.99
Fue útil esta respuesta?
Calificación 4
Comentarios:
I have a iPhone5s and it has black lines at the bottom and my screen won't work. What could be wrong? Could it be bcz I dropped it or banged it on something
por
I had the same issue on an iPhone 4S and I fixed it by warming it up to body temperature for 30 minutes or so. The lines gradually disappeared!
Calificación 4
Comentarios:
my phone has also horizontal lines at the bottom... is it really working by warming? many thanks!
por
surprisingly useful!! thank you!!!
por
how did you warm the phone
por
I held it between my legs :)
por
So, you didn't have to replace the screen? My iPhone 5s has the same issue and I don't know what to do. I would appreciate any advice
por
Mostrar 5 comentarios más
Hmm.. It depends on the lines. If they're black, it's usually the lcd. If white, then it's an issue with the digitizer. Yes, it can be repaired. If their white, you can try reconnecting the display cables, and cycling the battery. If black, you can easily replace the lcd, on that phone
Calificación 0
Comentarios:
It was a very helpful tip n I found the problem is with digitizer. Now the phone is working fine. Thanks
por
My lines are purple And i found them only in my camera please tell me what should i do?
por
What about purple all over, it comes back and leaves
por
mine was a series of green red black lines going downward then just quit
por
i need help. Currently my phone is black(bottom part of it) and the top part is mixed with purple dots and i cant fix it.I tried a the power method and such but i still couldnt make it work. Please help. (Samsung note 4)
Calificación 0
Comentarios:
My iphone5s some unresponsive touch .it cause a black thin horizontal lines on bottom.it increase while using brightness.what is the problem how to fix ?any body give idea please
por
My iphone 8plus has verticle lines and screen seems a bit deem then it used to be. Text also reflecting back on screen like copying of it. Not damaged or fall on ground for sure. Please advise. Does apple cover if its under warranty to fix it?
por
Añadir tu respuesta
binaryop8 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 170
Últimos 7 Días: 1,149
Últimos 30 Días: 5,752
Todo El Tiempo: 236,453
