Saltar al contenido principal
El Acer Nitro 5 AN515-53-55G9 es un portátil dirigido a jugadores de bajo presupuesto. Cuenta con 256 GB de almacenamiento, Nvidia GeForce Graphics y un procesador Intel i5 de cuatro núcleos a un precio más asequible que la mayoría de las laptops para juegos.
Preguntas 60 Ver todo
whenever I tried to pick my laptop it completely shut down.
when laptop is off power cable, I tried to pick then i suddenly shut down completely and if it has power cable on it works perfectly.
it only happens when off power cable and tried to pick other than that it works perfectly, so please help me.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi,
If it works OK when the charger is connected but not when working on the battery only, there may be a problem with the battery.
Have you checked that the battery is fully charging OK (100%) when the charger is connected to the laptop?
If it is even so it may be failing to hold its’ charge.
Try replacing the battery and check if that resolves the problem.
Here’s a link to the ifixit Acer Nitro 5 AN515-53-55G9 Battery Replacement guide which should be of some help.
Here’s a link to just one supplier. It is only shown to give an idea of the cost of the part. There are other suppliers online that may suit you better. Just search for Acer Nitro 5 AN515-53-55G9 battery to get results.
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Sameer Pathan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 109
