Saltar al contenido principal
iPhone de 4 pulgadas lanzado en marzo de 2016 con especificaciones de hardware similares al 6s. Disponible en Plata, Gris espacial, Oro u Oro rosa con opciones de almacenamiento de 16/64 GB. Modelos A1662 y A1723.
Preguntas 1047 Ver todo
I can’t get the home button bracket screws out!
Hi,
I have repaired 2 iPhone SEs so far, and every single one I have found the two screws over the home button bracket very hard to get out. I have ripped the bracket out successfully twice, but because of the shattered screen on this one, I cannot get it out at all! The screws are also now stripped!
Any ideas?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
On water damaged SE’s I have drilled the left screw out than covered the home button components and applied super glue to the screw on the right.
I than bend the bracket up from the left and turn the bracket hopping the right screw will come loose. If this doesn’t work I drill it out.
They are easy to drill out if you have the right tools. I use a Dremel with dentist bits. If I were you I would invest in some quality drivers for removing the screws.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
I’m definitely going to hive drilling a go, however where can I get the correct type? I searched for one, but had no matches. Thank you.
- de
I think I purchased mine from iPad Rehab but that was years ago.
- de
Añadir tu respuesta
TheRe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 102
