I dropped my iPod for the 1st time now screen doesnt work
I dropped my brand new iPod for the first time now the screen is black and is backlit a little bit, and it wont turn on
Es esta una buena pregunta?
This happened with my iPod touch 7th Gen, i thought the LCD broke too. Waited for it to discharge then it booted up normally after. If that does not work, replace the display (or have it replaced)
Fue útil esta respuesta?
Press and hold the Power button and the volume down button at the same time. When the Apple logo appears, release both buttons
this is what the tech chic told me to do, and it worked, twice now. Good luck!
Thank you! This helped me get it up and running. I still have vertical gray lines, but it works.
You broke the lcd. You can get this repaired via a new LCD/Glass. It’s not easy for a beginner but my shop charges $69.99 for it so it’s not crazy expensive to have a profesional do it.
Try a soft reset first holding the power and home button together for 10 Seconds.
Hi Dustin, where is your shop? My iPod Touch 7th Generation LCD is unresponsive to touch, and I need it fixed. I'm more of a beginner, and I don't want to mess this up. How can we communicate, so I could get this fixed?
Hey Liam, I’m not the best at technology repairs, but by the symptoms that were posted, the LCD Data ribbon came loose, not the backlight ribbon, which explains the working backlight. I would say your iPod touch is probably fully working, just open it and firmly but gently resocket all the display ribbon connectors in place and test the device while its open. If it were to therefore work flawlessly albeit opened up, that would solve your solution without spending $60+ USD. If not, replace the display for the 60 bucks USD and end your frustration. Good Luck to you and yours, Austin.
I had the same problem. It was fixed by waiting until the iPod was discharged and then pressing the upper button and the quieter button for 10 seconds. Then the display worked again and it showed me that the iPod was discharged. After that I could charge the iPod normally and it worked fine untill now.
Hi Liam:
Before I would open the iPod touch, I would follow the advice of Crazyblocks technologies and of Marcel. If this doesn’t help, I would open it and check if the LCD data ribbon cable broke loose, as The Bongo Guy suggested.
Steffen
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 52
Todo El Tiempo: 3,865
2 comentarios
my ipod shows a white and gray screen and won't turn off
- de The Bomb99
Discharge ? STUPID. You need to be permanently banned from making ANY kind of comment. Regardless of what it about or what type of Q&A website it is
- de Joihn Clark
