Saltar al contenido principal
Guías de reparación, desmontaje y soporte para lavavajillas.
Preguntas 699 Ver todo
LG will not drain
So I’ve watched all the videos, at first I got a partial drain with a error code, 0E, so I switched out after finding no obstructions, the drain hose. When I put it back together, I was able to drain manually. Then I ran a cycle and the dishwasher would not drain at all, no error code no draining. Then, according to other videos and questions, I thought it was a faulty drain pump. So I switched that out. Again when I turned it back on, I was able to drain it manually the very first time. I again ran a cycle, no error, but also no drain. So I seem to somehow make it worse. Has anyone ever had this happen. Same garbage disposal same everything, brand new hose kit, And a brand new drain pump. Any suggestions would be fantastic
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios:
Please give us your exact model number.
- de
Says
Inverter direct drive (without taking it all apart again), No: 3850DD3006X
- de
Agregar un comentario
1 Respuesta
This was the problem on my dishwasher. The check value was worn.
Maybe this video will help.
https://www.youtube.com/watch?v=dOs5XtLd...
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Jim M estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 101
