A question about compatibility between models
I have a 2015 Macbook pro with upper-end i7, full memory, and a good display adapter. Recently some liquid was spilled into the keyboard and now things are beginning to quit, like one of the USB ports for example. The display also has a crack in it. I was wondering if the memory, processor, or display adapter would be compatible with newer MBPro’s? I was thinking about buying a newer model and then upgrading it.
Thanks!
-BW
Update (12/13/2019)
Dan,
Sorry for this late reply. I have health concerns to deal with. Can you still assist me in finding a replacement display? I have a MacBook Pro (Retina, 15-inch, Mid 2015).
Here are the full specs...
Model Name: MacBook Pro
Model Identifier: MacBookPro11,5
Processor Name: Intel Core i7
Processor Speed: 2.8 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 6 MB
Hyper-Threading Technology: Enabled
Memory: 16 GB
Boot ROM Version: 194.0.0.0.0
SMC Version (system): 2.30f2
Serial Number (system): C02QW0WFG8WQ
Thanks!
- Bill
Es esta una buena pregunta?
3 comentarios
It seems you picked the wrong reference model, as the Macbook A1534 you chose doesn’t have an i7 processor, nor “ports”, it’s got an Intel M Cpu and a single Usb-C port. However, if you have as I believe a 2015 Macbook Pro 13” , not a single part is compatible with following models, Cpu and Ram are soldered on the logic board, Ssd is different, screen is different, even the charger is different.
- de arbaman
Thanks, arbaman. Of course, you are correct. It is an A1398. I had not looked before sending the request. My bad!
- de Bill Wilson
@Bill Wilson Not a problem at all. Unfortunately same thing goes with the big guy A1398 too, everything is soldered on the board.
- de arbaman
