Saltar al contenido principal
Decorational lighting used around the holidays.
Preguntas 22 Ver todo
Help! One side of house keeps burning out
Hello - So I have Christmas lights on both sides of my front door. Each side is on a different extension cord. However, the left side keeps shutting off. I’ve replaced the first and second strings of lights in the group, which seems to work for a time, but then the lights go out and the new string is burned out. Is one of the older light strings causing the problem? Should I keep replacing sucessive strings until it stops happening?
Thank you!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hello Alfred
A Merry Christmas to you!
1-Are the Christmas lights resistant to moisture? Of course, the heat of the LED is not high, but moisture can enter various parts. Since all lamps are similar, this is a reaction to the environment and moisture, so it is better to replace the set with a waterproof and insulated circuit.
2-Make sure the power supply circuit delivers the correct voltage and amperage to the circuit and no more, especially if you bought the power circuit separately .
3-Each LED has an internal resistance that reduces the current(V=IR). Replacing a string of lights with the other models probably is not a problem, but replacing two strings of lights with other models may leave too much current in the circuit due to the difference in internal resistance that will burn the rest of the LEDs.( upper limit for LED's is 20mA )
4-Adding a string more than the initial number to the group can reduce the current and be useful. I hope you also consider other environmental conditions.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Alfred Jackson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 266
